OEM Brush Guard
OEM Brush Guard
Hello there,
well I have a OEM Brush guard that I am going to be putting on. I do have everything needed too :-)
well started cleaning it up and sanding down and was just going to spray it with herculiner.
well found parts of it that was peeling off. Now I am scraping it off with a razor knife lol
yeah so much a quick clean up
The cause of the issues is these did not have drain holes, water gets inside and it rust from the inside out. You can sand and recoat, but the rust is going to come back. The only way to permanently resolve it is to strip completely, then either acid dip or remove the internal rust via electrolysis. Then you have to internally coat it before you coat the outside. Sorry for the bad news. I have one that needs the same thing.
I have to do the same thing as OP on my brush bar and plan on drilling drainage holes at the bottom.
cvhyatt (06-13-2020)
