OEM Land Rover Auxiliary Lights Not Working.
Old Dec 2, 2016 | 12:30 AM
TheWhiteRover's Avatar
Default OEM Land Rover Auxiliary Lights Not Working.
Used to frequent these forums, however I sold my rover 2 years ago and have missed them ever since.
Just picked up a 2004 Silver DII HSE7 with 130K on it.
She needs a little love, but I'll have her running and looking well in no time.
MY QUESTION.
As you can see in the photo, this one has the weird rubber bumper fitted with Land Rover OEM lights and look pretty awesome.
However, they don't turn on...
The button for them is directly under the Cruise Control Light and nothing happens when I press the button, the little light on the switch does't illuminate or anything.
A few other things it needs:
Plugs and wires Can I get them on Amazon?
02 sensors - I've found the BOSCH ones Front and Back on Amazon, are there any other brands that are worth it?
Prop Shaft Still has the factory one, going with Lucky8's cheap one unless yall have a better suggestion.
Attached Thumbnails OEM Land Rover Auxiliary Lights Not Working.-20161201_173349.jpg   OEM Land Rover Auxiliary Lights Not Working.-20161201_173412.jpg
Old Dec 2, 2016 | 08:44 AM
abran's Avatar
There is a factory relay box for those lights, I believe behind the engine bay fuse box towards firewall, they are notorious for failing. Check that.
Old Dec 2, 2016 | 09:44 AM
LR03NJ's Avatar
Check also the bulb. Had replaced mine few times. Also see if the cnnector behind grill if ok
tsuyoi
Sep 22, 2020 10:37 AM
booper169
Mar 20, 2019 09:37 PM
OEMPartHaus.com
Member Group And Special Buys
May 28, 2015 08:59 AM
AK Rover
Jan 11, 2009 11:40 AM
ghinesley
Nov 19, 2007 02:50 PM
