Off-Road Lights
Old May 27, 2009 | 11:20 PM
leeb2761's Avatar
5th Gear
Default Off-Road Lights
I have a 2000 D2 (second owner) the off-road lights only came on briefly then went off, the light on the switch also went off when the lights turned off. I turned the lights on a second time and they again turned off after a few seconds; now the lights will not turn on at all. I attempted to locate a relay for them, but was unable to find one marked for them (however all the other lights are marked, and they all work fine) Any suggestions for troublehsooting them?
Old May 28, 2009 | 12:29 AM
NiteTrain's Avatar
multi-meter and start tracing
Old May 28, 2009 | 07:42 AM
If you are talking about the factory off road lights, look in your owner manual for the relays location, or look inside the 2 fuse blocks, there should be a label showing what you need.
thehun
Dec 27, 2010 03:41 PM
tailchaser0527
Dec 5, 2007 08:51 AM
SpeedAgent
Aug 4, 2007 03:15 PM
iJeremy
Nov 1, 2006 11:49 AM
hymlopez
Mar 23, 2006 11:29 PM
