The Official Extinct Inline Thermostat Mod Thread
Old Jun 11, 2021 | 06:52 AM
  #91
TimInNova's Avatar
Originally Posted by dtmbinb
There's a dick in your cooling system. Lol! 🤣
No, that's just the Rover engineer that designed the original cooling system.
Old Jun 13, 2021 | 03:59 PM
  #92
rikkd's Avatar
I was looking at the 180 thermostat and wondering if it would affect emissions of the vehicle. I live in CA and have been having a hard time getting it smogged
Old Jun 13, 2021 | 05:33 PM
  #93
Extinct's Avatar
I kinda doubt it will affect the annual smog test as that test was not as detailed as the one the manufacturers had to pass. I'm sure you know all the normal tricks like high alcohol fuel, etc. If it did you could run a 190 element for the annual test and then change it to 180 the rest of the year.
Old Jun 14, 2021 | 09:39 PM
  #94
rikkd's Avatar
Is there any in stock? I've looked on the website and I get this message "The selected product combination is currently unavailable." I'm looking for a 180F thermostat.
Old Jun 15, 2021 | 03:38 AM
  #95
Extinct's Avatar
Sorry about that, web site still has a bug in it I have not found on the inventory system, still working on it but I updated it manually.
Old Jun 15, 2021 | 04:32 PM
  #96
rikkd's Avatar
Thank you! I just ordered mine!
Old Jun 16, 2021 | 06:13 PM
  #97
Richard Gallant's Avatar
@Extinct which part number is the thermostat, I want to do some testing with 170and higher quality thermostat
Old Jun 16, 2021 | 07:26 PM
  #98
Extinct's Avatar
You can order extra thermostats at inlinethermostats.com, basically any small block chevy thermostat will work but you will need to drill a 1/8" bleed hole in it so that it will open without spiking the temperature. The ones I have sourced have a punched precision hole and are not a standard pn due to that hole.
Old Jun 20, 2021 | 01:35 PM
  #99
TimInNova's Avatar
Originally Posted by Extinct
All good man, report back with actual temps when you can.
Tim:
Today it was 92 degrees out, so I went for a test drive to capture some readings.
My truck has only about 5 miles on a new radiator and water pump. All hoses were also replaced.
I used both my inline Auto Meter Sport-Comp 2 gauge, that measures right before the radiator, and a Bluetooth OBD2 gauge that is reading from the engine temperature sensor.
On average, the Auto Meter showed 10 degrees higher than the engine sensor.
On the highway at 65 MPH, the engine showed 197 F while the Auto Meter showed 210 F.
Around town I was seeing 188 F (OBD2) / 198 F (Auto meter)
My around town/idle temps are much lower with the inline thermostat.
I don't understand why the highway temps are so high, as they were always lower with the LR thermostat. Should I run a cooler thermostat or are these temperatures within acceptable range?
Images from the highway drive:
Old Jun 20, 2021 | 01:48 PM
  #100
@TimInNova With a black TD5 thermostat I get up to 188 -192 at hiway speeds. Partly clogged cats can cause in increase in temps at higher RPMS, a exhaust back pressure test can check for cat performance.
Running lean can also cause temp rises, Are you sure you have all the air purged and no other issues.
