The Official Extinct Inline Thermostat Mod Thread
#462
Just noticed some old posts being bumped up at Landyzone about TD5 inline kit.
https://www.landyzone.co.uk/land-rov...wanted.372486/
Dervish (01-23-2024)
#463
Quick info check while I'm here.
Cold in Indianapolis, single digits. Highway speeds (mid 70's) temps running 165-175 on a scan gage 2. Off the highway and regular roads, stop and go, still single digits, idling at a light, and the temps on the gauge will go from 175 to 200, then back down when I go on. Never above 200°.
New top hat engine 20K miles ago, new everything. Coolant level rock steady. Your kit. I do get a "gurgle" occasionally, a short waterfall sound.
Thoughts?
Thoughts?
#464
Thoughts?
Thoughts?
#465
Thoughts?
Thoughts?
H Hill (01-24-2024)
#466
#467
Any recommendations on coolant with the inline setup form this thread?
I just order the inline system and solar setup. I will be rebuilding my 04 Discovery hse. Headgasket and check heads and new hoses valve cover gaskets and relocating the coilpacks since it's apart and new alternator bracket and some pulleys. And the inline system. Then I'll be updating the suspension as it's now 12 yrs old. Thx for this thread and @Extinct for the experience and sharing. Can't wait to remove the nasty in the picks.
#468
The inline kit dropped my temp but also during my head gasket replacement, it made draining and bleeding so much easier!
The following 2 users liked this post by Roont:
PD2004USSalty (03-05-2024),
YETIX (03-05-2024)
#469
The following 2 users liked this post by Harvlr:
YETIX (03-05-2024)
#470
Agreed. I flushed mine twice with hose water and twice with distilled water before putting in the new coolant. Using a kiddie pool to catch the coolant makes the job much easier as does putting a worm clamp on the lowest radiator hose and using the right lower water pump bolt to drain the coolant. I installed the inline kit without the thermostat, then filled the coolant via the expansion tank, ran the engine for a couple of minutes, then drained. Rinse, repeat. Made the job super easy and I completely flushed it and filled with new coolant within a couple of hours. Biggest issue was getting the old coolant and water from the kiddie pool into jugs for recycling.
