Oh Cmon!!
Old Mar 29, 2017 | 08:58 PM
robert.juric's Avatar
Default Oh Cmon!!
Well I snapped the connection for the crankcase breather. I thought there was enough left to get an extractor on it but it was almost a flush break. Any ideas to clean out the plastic from the threads or is it possible to work around this connection?
Old Mar 29, 2017 | 09:03 PM
Luckyjayb's Avatar
if you have a soldering iron, you can melt the plastic in 2-3 spots, and then maybe you pop it out that way. Or use a screw driver and do it like that. It's a pia either way u look at it
Old Mar 29, 2017 | 10:02 PM
mln01's Avatar
I think I just jammed a screwdriver in it and turned it. It's amazing how sometimes the little things become such big pains in the ****.
Old Mar 29, 2017 | 10:05 PM
Jeff Blake's Avatar
This reminds me to swap for a brass nipple.
Old Mar 30, 2017 | 06:54 AM
Luckyjayb's Avatar
they have a brass version
Old Mar 30, 2017 | 07:05 AM
OverRover's Avatar
At Home Depot or Lowe's > Watts/ A-293
To get the old piece out a very cheap bolt extractor will get it done fast > http://www.harborfreight.com/screw-extractor-set-12-pc-61981.html
Old Mar 30, 2017 | 08:01 AM
Best4x4's Avatar
Yep any auto parts store will carry them as well. They're normally located by the air tool accessories.
Old Mar 30, 2017 | 08:48 AM
Alex_M's Avatar
You can just put some tape over it for now if you need to drive the truck. Just also clamp off the breather on the other side so you don't have a vacuum leak.
Actually, I ended up doing this because I was tired of getting oil in my intake and didn't want to take the valve covers off to replace the oil separator.
Link: Oil Breather Mod
Old Mar 30, 2017 | 10:00 AM
Thanks Alex, I needed that just to test something else. Thanks for the link as well since I do see some slight oil in the intake as well.
Does anyone think a tap would clean the threads out?
Old Mar 30, 2017 | 10:32 AM
OverRover's Avatar
IMHO a tap is a bad idea. Because the plastic is blocking the starter threads, you run the risk of cross threading the original threads with the tap. An internal bolt/screw extractor (SEE POST #6) works very well. Used one many times and it always worked.
