oil change
Old Dec 3, 2008 | 08:21 PM
roverboy's Avatar
Default oil change
Hello just bought my 96 se portofino red discovery about a month ago and the previous owner had changed the oil I'm like 700 miles due to oil change would it be ok to change now I just want to do it so it will be my first oil change on the truck
Old Dec 3, 2008 | 08:29 PM
sloppyjoe's Avatar
Default RE: oil change
sure! why not,,,
Old Dec 3, 2008 | 08:44 PM
roverboy's Avatar
cool will do
Old Dec 3, 2008 | 08:49 PM
Well you can never change the oil to soon or to often.
Here is what I do and what I recommend to everyone who will listen.
I use Mobil 1, you can use any full synthetic that you want.
I change ti every 5,000 miles.
I just changed it at 175,000, so next oil change will be at 180,000.
Everytime there is a "5" or a "0" third spot from the left change the oil, dont worry about the "100's" numbers, just the "5" or "0".
Sometimes you will change it early, sometimes late but as long as you always change it when there is a "5" or a "0" third from the left you will be just fine.
If you use non systhetic oil then you must change it every 3,000 miles. Much harder to keep track of.
Using my method there is no need for a oil change sticker or to write it down.
How many miles on your truck right now?
Old Dec 3, 2008 | 09:43 PM
sloppyjoe's Avatar
if i was you, i would change to synthetic now. 10w40 in either mobil 1 or amsoil. i just swapped to the mobil 1 high mileage synthetic. my rig only has 50k and change on the odo but i felt compelled to condition the seals sooner rather then later.
since i will only drive the rover about 10k miles a year or less i will swap the oil twice a year regardless of miles.
like spike said, change it every 5k miles and enjoy the rig.
Old Dec 3, 2008 | 11:38 PM
roverboy's Avatar
119,400
Old Dec 4, 2008 | 12:58 AM
sloppyjoe's Avatar
ORIGINAL: roverboy
119,400
go with some of the synthetic oil for high mileage engines,,, enjoy
Old Dec 4, 2008 | 01:35 AM
Disco2Guy's Avatar
There's been an interesting thread on DWeb about oil and it's specs, related to the flat lifter engines in the Rovers. If you choose Mobil1 go with the High Mileage type 10W-30 or 10W-40.
http://discoweb.org/forums/showthread.php?t=54420
Old Dec 4, 2008 | 10:31 AM
sloppyjoe's Avatar
my head almost exploded reading all of that,,,
Old Dec 4, 2008 | 04:16 PM
lrd2's Avatar
ok i have a 2002 d2 with 96600 i am currently using 20-50 synthetic blend i have beed iffy about going to full synthetic because am not sure which one to use. i drive about 11k miles a year and 10k of thouse are done by my wife. what do you guys thinks i sould use from now on?
