oil change
Old Dec 4, 2008 | 04:47 PM
roverboy's Avatar
Default RE: oil change
keep using 20w50 were do you live?
Old Dec 4, 2008 | 06:55 PM
ORIGINAL: roverboy
119,400
So change it at 120,xxx, then again at 125,xxx, then 130,xxx and so on and so on.
Old Dec 4, 2008 | 07:02 PM
lrd2's Avatar
i use 20-50 synthetic blend i want to use full synthetic but which one should use. i live in miami florida
Old Dec 4, 2008 | 07:07 PM
Because you live in Miami stay with the 20w-50, switch to full synthetic, you will have use Castrol Syntec, that is the only full syn that I know of.
You could also use Mobil 1 15w-50. That is what I use in the summer.
Old Dec 4, 2008 | 07:16 PM
lrd2's Avatar
is there much of a difference between the 15-50 and the 20-50 my wife drives it most of the time but when i drive it i have a pretty heavy foot i dont take it off road any more since i busted the front drive shaft
Old Dec 4, 2008 | 07:23 PM
Well the 15w-50 will pump easier when cold then the 20w-50, but you wont notice any differance.
Both will give the same amount of heat protection.
Whichever one is more easaly avalible in your area is the one that I would use.
Now about your driveshaft, you are not driving around with it removed are you?
Old Dec 4, 2008 | 07:53 PM
lrd2's Avatar
no i replaced it it went out the next day after i went off roading it just poped right off i bough an oem from ebay for 250.
dealer wanted 900 for parts
Paul3221
Nov 25, 2013 12:12 PM
drewski
May 31, 2013 10:50 AM
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
tito5590805
Oct 4, 2010 09:11 AM
