OIL CHANGE
Old Jul 10, 2007 | 04:11 PM
morganmfoster's Avatar
7th Gear
Default OIL CHANGE
I am thinking of changing to synthetic oil because my 99 disco II has 121,000K. Does the system need to be flushed or can I drain the regular oil and just fill it up with syntec?
Old Jul 10, 2007 | 04:16 PM
98roverguy's Avatar
Default RE: OIL CHANGE
I was taught in school that changing to synthetic that late (in terms of mileage) is not a good thing. Damn if I remember why, but others may think different.
Old Jul 10, 2007 | 04:20 PM
Flush the engine first and go for it. Be prepared to possibly change it early after switching over cause a synthetic will loosen up alot of old junk. Also keep an eye open for any new oil leaks, sometimes an old leak will get worse on synthetic.
As for the logic, I would do it.
Mike
Old Jul 10, 2007 | 04:43 PM
7th Gear
How do I flush it? I may just need to let a shop do it the first time and I'll continue from there
Old Jul 11, 2007 | 07:29 AM
Landzu's Avatar
You can get Mobil One Highmileage synthetic now in 10w30 and 10w40. I changed from
the reg Mobil One to the highmileage and it almost stopped all the little oil seepage
spots on the motor.
To flush the motor you can use ATF six qts and a new oil filter and let it idle for 20 mins,
not driven and then change it as normal, new oil and oil filter.
Old Jul 11, 2007 | 09:47 AM
Good idea.
I doubt you will find a shop that can flush your engine, For under $15 you can do it your self.
Mike
Old Jul 12, 2007 | 05:39 AM
mordor110's Avatar
Yeah watch for leaks/seapage after. I switched an engine over once and the front main started seaping right after.
Paul3221
Nov 25, 2013 12:12 PM
drewski
May 31, 2013 10:50 AM
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
tito5590805
Oct 4, 2010 09:11 AM
