Oil Change PA
RE: Oil Change PA
I have a couple of basic questions and this seems as good of place as any to ask: How do you check the transfer case fluid, transmission fluid, and how do you grease the front drive shaft (do you just put the nozzle on the zerk and squirt?)? is there any other fluids/ other thingsthat should be checked while under there? Sorry for high-jacking the post but I am used to oil changes in cars and am mechanically inept. Up until now I have been going to a local place but that is getting expensive. Thanks
RE: Oil Change PA
ORIGINAL: salve7
I have a couple of basic questions and this seems as good of place as any to ask: How do you check the transfer case fluid, transmission fluid, and how do you grease the front drive shaft (do you just put the nozzle on the zerk and squirt?)? is there any other fluids/ other things that should be checked while under there? Sorry for high-jacking the post but I am used to oil changes in cars and am mechanically inept. Up until now I have been going to a local place but that is getting expensive. Thanks
RE: Oil Change PA
ORIGINAL: tkos5250
Hi everyone. I just recently got a Discovery II. I was wondering if anyone is from the mainline Pennsylvania area and where you normally go for oil changes. I know the dealership wants $110. I feel as though that might be a little high but I could be wrong.
Thanks
Thanks
Salve-since nobody else wants to spend the time to type it up I will.
The fill plug is on the back of the transfer case, take a 1/2" rachet with a extention, find the fill plug, it is beside the parking brake drum, there will be wires in the way, take it out, stick your finger straight in, if it gets wet, you are full.
As for the transmission, how to check the fluid level depends on if you have a DI or a DII.
On a DII there is a fill plug on the side of the transmission under the truck, check the fluid level the same way as the t-case.
On a DI there is a dipstick in the engine bay, engine running, trans hot.
The front and rear differentials are the same, remove the fill plug, stick in your finger, do this on both diffs.
Check the fluid in both diffs, transmission and t-case every 6 months, unless you have a leak then every 3 months, major leak once a month.
RE: Oil Change PA
if you see that any of your diff fluids are milky in color, like for instance if your trans fluid is the same pink opaque color as pepto bismal, then change them immediately, the milky coloration is due to water getting in there, which is not completely out of the ordinary... and as i'm sure you already know, oil and water do not mix...
________
AdorableBrina
________
AdorableBrina
