Oil Change PA
Old Nov 19, 2008 | 09:43 PM
Default RE: Oil Change PA
Jiffy lube will use a cheap oil filter but any brand of oil that you ask for.
If you want Quaker Statethen ask for it, Valvoline, ask for it, Mobil 1, ask for it.
You can go to NAPA and buy your own oil filter and have them put it on for you.
Fram, Purolator and Wix are the oil filters that the quick lubes use, they just put their own name on them.
Old Nov 20, 2008 | 01:03 PM
salve7's Avatar
Thanks spike my next question is how do you fill them if they are low? Tapper, I have been taking my own filter to the jiffy lube place because they use regular filters with the synthetic and I wanted something that would last a little over 3,000 miles. It only saves you around a buck off the oil change which I think sucks but at least I know my oil is cleaner. Our local auto supply stoers here always have deals where you can get 5 or 6 qts offull synthetic and a good filter for around 30 bucks.
Old Nov 20, 2008 | 04:04 PM
Well they are supposed to be checking and topping off your driveline fluids at the quick lube when they change your oil. Ask them to make sure that they do it.
The easiest way for you to do it yourself is with a fluid hand pump, you can buy one at any autoparts store.
You dont need a good one, the $5 pump will do just fine.
You can also have the quick lube change your t-case and diff fluids for you, its about $50. More if you want full synthetic.
Old Nov 20, 2008 | 04:07 PM
ORIGINAL: Tapper
Is going to a place like Jiffy Lube a good idea. Anything to worry about the quality of the oil or filter that they use?
If you want to use a lube shop make sure to take your own filter, a K&N 3001 or a Mobil1-301 have them use it and give you credit for their junk filter.
Old Nov 20, 2008 | 04:09 PM
ORIGINAL: salve7
Thanks spike my next question is how do you fill them if they are low? Tapper, I have been taking my own filter to the jiffy lube place because they use regular filters with the synthetic and I wanted something that would last a little over 3,000 miles. It only saves you around a buck off the oil change which I think sucks but at least I know my oil is cleaner. Our local auto supply stoers here always have deals where you can get 5 or 6 qts of full synthetic and a good filter for around 30 bucks.
When where all you other fluids changes, should be every 30,000 or less and checking them isn't going to keep your truck serviced properly.
Old Nov 20, 2008 | 05:08 PM
salve7's Avatar
They were replaced about 20,000 miles ago when I purchased the truck so I prob need to do that again soon. Spike the lube place has been checking that stuff for me but only because I didn't know how to do it. It makes me sick having to rely on the lube place to get it right and its about $85 a pop, so I am trying to do it all myself again. I just don't want to forget something that they have been checking and wind up screwing myself. I am assuming you just pump it in until it runs over? Any reccomendations on which brands to use?
Old Nov 20, 2008 | 05:15 PM
Yes, you pump it in until it come out.
As for brands...any name brand will do. I use full synthetic 85w-140 and change it every 50,000 miles.
Diff fluid doesnt break down like motor oil does, it lasts for a long time, especially full synthetic.
My FedEx van has 206,000 miles on it with the original diff fluid in it.
Old Nov 20, 2008 | 05:20 PM
salve7's Avatar
Thanks folks that is a lot off of my mind. I'll give it a go here in about 3,000 miles or so!
Old Nov 20, 2008 | 05:33 PM
Tapper's Avatar
I went to NAPA to get an oil filter. They had K&N HP-3001 and HP-2004. What is the difference and which do you guys think is better.
Thanks.
Old Nov 20, 2008 | 06:28 PM
Alot of guys on here like the K&N oil filters, I wont pay $12 for a oil filter when a $5 filter does the same job just as well as the $12 filter.
