oil change problem
RE: oil change problem
http://img.photobucket.com/albums/v3...overoilpan.jpg
if you cant see the picture then copy the address above this sentence into your web browser.
that bolt is the oil drain plug bolt right? well i cant take it off with my 1/2inch socket drive because that pipe to the left of it gets in the way. i tried using an adjustable wrench but i stripped the bolt a bit so i stopped. righty tighy leftly loosey right? disco mike, what kind of oil and oil filter do u recommend? the engine has 109,000 miles. thanks for your help.
collin Barrows
08-28-2011 07:13 AM
