Oil Change Question
Old Feb 14, 2006 | 01:03 AM
sclarkie's Avatar
Default Oil Change Question
The owner's manual for my 2001 Disco II tells me to drain and then re-fill the engine oil before removing and replacing the filter; why, and does it make a difference if I take it off and replace when I drain it?
Old Feb 14, 2006 | 10:14 AM
Landzu's Avatar
Default RE: Oil Change Question
You could lose prime on the oil pump.
I have done it both ways doesn't seem to matter.
Old Feb 14, 2006 | 03:49 PM
mikemeyer0's Avatar
the motor you have will loose prime if setting too long. do this way:
1. Drain oil
2. remove oil filter
3. fill new filter with oil, let it set so you can add more and fill more, 1/2 qrt. or so total
4. put on new filter w/ 1/2 to 3/4 qrt. new oil
5. Make sure previous oil filter gasket is not stuck to block (you would be amazed how many people do this)
6. re-fill block with new oil
7. start engine, run for about 5 seconds, or till the oil pressure light is off, the check oil level.
Old Feb 15, 2006 | 03:44 PM
Landzu's Avatar
Also make you have the beer iced down prior to service.
This makes the mess that you make of little consequence. [sm=icon_cheers.gif][sm=partyparty.gif]
Paul3221
Nov 25, 2013 12:12 PM
drewski
May 31, 2013 10:50 AM
collin Barrows
Aug 28, 2011 07:13 AM
mwindth
Dec 21, 2010 08:28 AM
tito5590805
Oct 4, 2010 09:11 AM
