oil change time!!!
Old Sep 2, 2008 | 01:35 AM
sdsilvere38's Avatar
Default oil change time!!!
I have a 96 disco with 115,000 on it. Would 20-50 oil work well and what is the capacity?
Old Sep 2, 2008 | 02:26 AM
AK Rover's Avatar
Default RE: oil change time!!!
The capacity is 7 quarts. I don't think 20-50 is recommended by LR. Spike will recommend 15-40 but I personally have switched to Royal Purple 5-40 because of where the truck is located. 15-40 would be too thick for me when it gets cold.
Old Sep 2, 2008 | 08:17 AM
Depending on where you live and how cold it will get before your next oil change...20W-50 will work just fine. That is what I used to use in full synthetic form but I cannot get it anymore so I switched to 15W-50.
The "W" stands for winter use. So if it has a "W" in the nubers then it is ok to use in the winter.
Where do youi live?
Old Sep 2, 2008 | 08:45 AM
Well if you live in some place where it is warm all the time, like...San Diego then 20W-50 is a good choice and you can use it year round.
Old Sep 2, 2008 | 11:04 AM
Yep, good ole San Diego. I use 20w-50 in all my bimmers and it quiets them nicely as well. Thanks guys!
Old Sep 2, 2008 | 11:14 AM
Agreed, I use 15W-50 and my LR and my wifes Volvo are both quieter than it I used a 10W-XX, like I said the only reason I stopped using the 20W-50 is because I cannot find it anymore in a full synthetic.
I ran it in my '01 Montero from the first oil change at 5,000 miles until I had to get rid of it at 100,000 miles, changed it every 5,000 and never once did I have to add oil or ever have a oil PSI issue, even in the dead of winter and it was below zero.
That engine was as clean after 100k as the day I brought it home with 62 miles on the OD.
I used Castrol Syntec.
If your tight BMW can take it then your loose Rover can too.
Old Sep 2, 2008 | 03:08 PM
Switzer's Avatar
I run 10w40 Maxlife. Colorado is a touch colder in the winter so I run a 50/50 mix of 10w40 and 5w30. Don't ask me why because I really don't know.
Happy Roving,
Pete
LADEROUTE
Jun 10, 2012 06:24 PM
urq
Mar 14, 2012 11:33 AM
collin Barrows
Aug 28, 2011 07:13 AM
iplayblues4u@comcast.net
Dec 11, 2009 10:00 AM
mwindth
Mar 30, 2009 08:18 AM
