Oil Cooler ?
Old Jan 30, 2007 | 09:57 AM
JBRIII's Avatar
Default Oil Cooler ?
I think my 02 Disco II has the Engine Oil Cooler. It is within the VIN# Range.And there are some tubes running to and from the oil pump housing.Could someone explain it's operation to me? Is it an air exchange cooler or is it water cooled? Any benefit or drawbacks to having one? Have read that they can sometimes prevent the oil from heating to proper temp to burn off any fuel/condensation.
Thanks,
John
Old Jan 30, 2007 | 12:14 PM
Default RE: Oil Cooler ?
Your oil cooler is an air cooled system, benefits are keeping the engine operating temp designed by Rover, they do not plug up or get restricted as long as you do your 3000 mile oil changes. They are not a problem for letting the engine get to operating temp, the t/stat takes care of that.
Mike
Old Jan 30, 2007 | 12:33 PM
JBRIII's Avatar
10-4, where is the exchanger? Is it a stacked plate type system in front of the radiator?
No problem with the OCI. I'm extremely **** about changing the oil on time.
Thanks Mike.
John
Old Jan 30, 2007 | 04:30 PM
Yes, it is mounted in front of the radiator,
Living in Colo, my 99 warms up plenty fast when it is 5 or 10 degrees out in the AM.
Mike
Old Jan 30, 2007 | 05:06 PM
JBRIII's Avatar
Thanks Mike. I finally found it on my Rave CD. Good to know I have it with an aluminum engine.
Rufflyer
Mar 22, 2015 10:13 AM
Beaulim
May 2, 2014 08:03 PM
wheelgarage
Dec 29, 2012 01:50 PM
javven
Jul 15, 2012 10:09 AM
