Oil Cooler Release Rings
Old Feb 16, 2008 | 08:36 PM
focusontheworld's Avatar
Default Oil Cooler Release Rings
We are replacing the radiator on a 2001 Discovery II. To remove the old radiator we have to disconnect the oil and gearbox oil cooler lines. The release rings on the oil cooler and gearbox oil cooler lines where they connect to the coolerwill not release the connection. Does anybody have any tricks on disconnecting these? Thx. Tom.
Old Jan 25, 2011 | 08:21 PM
2001SE7's Avatar
Well.... that answers that question.
Old Jan 25, 2011 | 09:16 PM
lordmorpheus's Avatar
Lol! When I pulled the radiator in mine when replacing the engine, I couldn't get the lines loose from the transmission or oil coolers either, and I consider myself a pretty smart guy. So....
I left the lines attached to the coolers, unbolted the coolers, and moved them out of the way to pull the radiator. Took a bit longer I'm sure, but didn't lose any fluid!
Old Jan 26, 2011 | 06:09 AM
Bundu's Avatar
Banned
Push the connectors in as though you are pushing them on, then press the tit and wiggle it off. You need to release the pressure on the connector before you can get it off.
Old Jan 26, 2011 | 03:24 PM
2001SE7's Avatar
Default :)
I got mine off last night but I had to break LR's release rings off and use some I bought at NAPA. LR's plastic isn't stiff enough on most or we wouldn't be talking about them(most likely from aging I figure or poor quality). Some were still a little hard but with the right combination of swear words they'll pop off.
Beaulim
May 2, 2014 08:03 PM
mattrickman
Aug 22, 2012 05:21 PM
javven
Jul 15, 2012 10:09 AM
danvlarsen
Nov 20, 2010 07:19 AM
