Oil in Cylinder 1 with low compression
Ok So I ordered the Head Set from Beck Arnley w/o head bolts
I have a new thermostat,oil,filter,oil seprator,engine degreaser
What else should I have on hand before I tear it down?
And let us not forget a trip to the machine shop to have heads at least checked for flatness, the spec is 0.002 inch, so that is about 1/2 the thickness of your printer paper. You can check yourself with suitable straightedge and feeler gauge, see RAVE. Will also need sealant for the corners of the valley pan gasket.
xb70valkarye
Mar 31, 2009 01:31 AM
