oil filter
Old Mar 18, 2008 | 04:41 PM
newdr's Avatar
Default oil filter
i sent for a k&m oil filter online and they sent a 2004 part # not the 3001 you speak of for my 2003.
ok?
Old Mar 18, 2008 | 04:45 PM
llesra's Avatar
Default RE: oil filter
yea that one works. the 3001 is preferred over the 2004 because it has a larger capacity. where did you get the filter from? did you specifically request a 3001?
Old Mar 18, 2008 | 05:07 PM
jkid's Avatar
They usually list the 2004 filter as required for Land Rovers.
Old Mar 18, 2008 | 07:48 PM
antichrist's Avatar
Getting oil filters by mail is crazy, unless you're buying other stuff to make shipping worthwhile, or you're buying a case. Next time just get a Wix filter locally, about $5 or $6 and they are excellent flters. PN is 51515. NAPA Golds are the same filter. This one is a bit taller than the OEM for a bit more capacity. I can tell you the OEM size too, but would have to look it up.
Update (cut and paste from a post I made a while back on another forum):
The Wix oil filter is 51068. There are two others, of higher capacity in case people are interested.
The 51515 (which I'm using) which is the same except 5.178" tall rather than 4.338"
There is also the 51773 which has a two quart capacity and is 6.982" tall. (I used this one for a while but had to quit when I relocated my steering damper as it as too long)
They all have the anti-drainback valve and 8-11psi bypass valve.
bigugly82
May 7, 2007 09:38 PM
mike.anna
Apr 13, 2007 09:57 PM
DefenderTd5Dude
Defender
Mar 20, 2007 04:22 PM
bigugly82
Mar 6, 2007 10:55 PM
fuel
Dec 13, 2004 04:49 PM
