PINION SEAL
Old Mar 17, 2008 | 02:17 PM
newdr's Avatar
Default PINION SEAL
EVERY TIME I TAKE MY 2003 D2 TO THE DEALER THEY FIND SOMETHING.
THIS TIME A LEAKING FRONT PINION SEAL THEY WANT TO FIX FOR $350.
IMPORTANT? 83K
Old Mar 17, 2008 | 03:06 PM
Mark G's Avatar
Default RE: PINION SEAL
It will eventually need to be changed. If it's just a tiny bit moist around the seal, you could hold off for a while. If it is more than that, would be a good idea to change it. That price seems high for changing a pinion seal, but I haven't done one for a L/R. For most vehicles, it's a 1/2hr or 45 min job. There might be a crush washer that needs to be bought/installed. Go with a Land Rover seal no matter who does the job. OEM is almost always better than aftermarket parts store seals. Good time to put in new Gear lube too.
Old Mar 17, 2008 | 03:12 PM
Just keep your level full, check it once a month or so depending on how bad it is leaking. Does it actually leak or is it a seaper?
Old Mar 18, 2008 | 04:15 AM
antichrist's Avatar
ORIGINAL: Mark G
That's like saying OEM tires are better than aftermarket. It depends on the seal you use.
newdr, FWIW I just replaced one of mine for $20 worth of parts, and that included a new locknut on the pinion.
Old Mar 18, 2008 | 06:42 AM
jkid's Avatar
Do you still have the original u-joints in your shaft? A vibrating driveshaft can cause your pinion seal to fail, so you may want to get your driveshaft rebuilt when you have it off. A transmission shop would probably replace both of those for you I bet.
Old Mar 18, 2008 | 02:09 PM
Mark G's Avatar
It's not the same argument at all. Seals are almost always proprietary, tires are not. If you compare thetypical CR and other typical parts store brand aftermarket sealsagainsttheOEM seals be itGM, Toyota, Nissan, Land Rover and other makes, there is typically nocomparison of quality.I say "typically" becausethere are times where aftermarket companies source sealsdirectly from themfgr or mfgr supplier.But that is the exception and not the rule ...and ya never know what you'll get until you open thebox.
After problems with leaks, I finally got to the point where Ijust quit buyingaftermarket seals. Generallyit only costsa couple bucks more, if even that, from the dealer, and then ya only havedo the job once.
Old Mar 18, 2008 | 02:39 PM
newdr's Avatar
THE U JOINTS ARE ORIG, BUT NO VIBRATION I CAN FEEL.
Old Mar 18, 2008 | 03:48 PM
jkid's Avatar
You may not feel it. At your mileage, I would replace the u-joints with greasable ones while you have the shaft off. As far as the seal, if oil is getting out, it seems logical that water can get in too. Not as bad as with the rear seal which gets a lot of road spray though.
Old Mar 18, 2008 | 07:56 PM
antichrist's Avatar
ORIGINAL: Mark G
Sure, a "Land Rover" pinion seal looks different, but that has nothing to do with quality. There's nothing unique about a Land Rover shaft and bore as opposed to any other make of shaft and bore. If you size a seal properly, buy a design suitable for the application (there are a lot of seal profiles) and install it properly, it won't leak, provided your shaft and bore are in good shape. Proprietary and quality are not the same thing.
I've been using non-OEM seals for over 30 years on Land Rovers with no problems.
s10lowrider1994
Feb 3, 2012 08:57 PM
amaxson
Jun 26, 2011 06:59 PM
discoboy
May 12, 2011 12:36 AM
LRScott
Jun 2, 2009 08:37 PM
garover
Feb 20, 2005 11:08 PM
