Oil Leak
Old Nov 11, 2020 | 09:49 AM
Fanuvkorn's Avatar
Default Oil Leak
Where do you think the oil is coming from in this pic?
Facing from Passenger side. Right below header. Front of engine is black.
Old Nov 11, 2020 | 09:53 AM
Fanuvkorn's Avatar
Default Oil pan
Oil Pan
Old Nov 11, 2020 | 06:16 PM
Extinct's Avatar
Valve cover and/or front of intake gasket. My bet is you have not done PCV mod, do that, clean off oil, report back. Oh, and tighten the outside valve cover bolts.
Old Nov 11, 2020 | 09:06 PM
Fanuvkorn's Avatar
I have done the PCV mod. I degreased it and will finish tmrw. What socket is it again for the valve covers?
Old Nov 12, 2020 | 07:37 AM
ahab's Avatar
12pt 10mm. Stupid choice.
Old Nov 12, 2020 | 08:32 AM
Extinct's Avatar
Oven cleaner is an excellent degreaser for that heavy cooked on grease. Purple power/Castrol super clearn is good but not as strong. Double check PCV functioning by putting a balloon or latex glove over the valve cover oil fill tube with the engine running, make sure there is suction not pressure.
Old Nov 12, 2020 | 08:33 AM
mollusc's Avatar
It also needs to be either a deep socket or a 1/4" drive to be able to clear the sides of the wells.
Old Nov 12, 2020 | 12:37 PM
Harvlr's Avatar
I'm pretty sure it's 8mm, not 10, but this is from memory.
Old Nov 12, 2020 | 01:06 PM
ahab's Avatar
I stand corrected, it is an 8mm. Apologies.
Magnolia18
Jun 23, 2024 06:31 PM
merebel
Off Topic
Jun 8, 2020 06:15 PM
sayeedA
Feb 19, 2017 03:04 PM
DiscoRover007
Aug 28, 2011 11:44 AM
