Oil leak
Old Apr 1, 2014 | 07:04 AM
drowssap's Avatar
passenger side valve cover
Old Apr 1, 2014 | 07:08 AM
ninjaff21's Avatar
If its valve cover do i need to just tighten or replace a seal
Old Apr 1, 2014 | 07:17 AM
drowssap's Avatar
in the back of the valve cover is an approx. 1/2 tube with a vacuum line on it,
if you remove the line the oil separator is inside the tube on the valve cover. it can be removed with needle nose pliers, but they can also break trying to get them out.
so first I try cleaning it with carb cleaners
Old Apr 1, 2014 | 04:02 PM
Dane!'s Avatar
Good info, thank you drowssap and FranceOffroad.
Ninjaff21, I would say tighten it first and see if your leak persists, then change it if it continues. Also, if you can pull your viscous fan off that would allow you to really spot your oil leak.
Thanks,
Dane.
Old Apr 1, 2014 | 06:25 PM
ninjaff21's Avatar
when you say carb cleaners do you mean doing something like a sea foam?
Old Apr 1, 2014 | 07:06 PM
ralphobell's Avatar
No it is carburetor cleaner. Like B12 Chemtool.
Berryman B-12 CHEMTOOL Carburetor/Choke Cleaners - 16 oz aero b-12 carb/choke cleaner (Set of 12): All-Purpose Cleaners : Walmart.com
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
