Oil Leak
Old May 17, 2007 | 12:35 AM
johnnybob06's Avatar
Default Oil Leak
So, after reading alot of the threads, I'm guessing an oil leak is pretty common with our lovely babys. Well.. how do I stop it??
I just changed the oil over the weekend, and right before changing it I noticed some oil leaking... nothing big at all.. not even a drop on the ground.
Now, after changing the oil and making sure verything was tight, there are oil marks on the ground....
I heard of head gaskets, valve something rathers...so what do I do??
And if I do need to replace, lets say a gasket or something major, would an extended warrenty pay for it??
Thanks a bunch!!
John-Robert
Old May 17, 2007 | 08:06 AM
Aquaholic's Avatar
Default RE: Oil Leak
Mine has leaks too (03 SE) - not showing on the ground.It's in the shop now to get them fixed under warranty, I'll let you know what happens.
Old May 17, 2007 | 02:08 PM
Send me your tele number and we will talk about your leaks and what to do about them.
Mike
mikeljacobs@comcast.net
Old May 18, 2007 | 09:16 AM
Aquaholic's Avatar
Dealer said they couldn't find any leaks
Old May 18, 2007 | 09:32 AM
I would crawl under neight and look for your self. If you van find drips then go see the dealer and have them put it on a lift so you can look with them.
If you only have damp oil residue build up they won't cover that.
Mike
Old May 21, 2007 | 07:14 PM
lowill's Avatar
My oil pan gasket was leaking to I changed it out months ago. Have'nt leak since.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
