Oil leak
Old Feb 10, 2015 | 12:03 PM
ewbourne's Avatar
Default Oil leak
Just had the oilpan gaket replaced because it was leaking at the front. Now it is leaking at the back where the pan and bellhousing are mated. Are these things just going to leak? What can be done?
Old Feb 10, 2015 | 12:42 PM
dusty1's Avatar
i use right stuff with it
also there are 2 types of gasket... have better luck with the rubber one
Old Feb 10, 2015 | 08:28 PM
Kenso's Avatar
Mine doesn't leak a drop with a new oem gasket. There was a TSB that recommended applying RTV to the heads of the 2 bolts in the recessed holes towards the rear of the pan to prevent leaks in that area. Also a good idea to use RTV on the gasket itself, at least in the areas shown in the RAVE if not the entire surface.
Old Feb 16, 2015 | 08:41 AM
me6067's Avatar
It is possible that it's not your gasket leaking and rather your rear main seal.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
