Oil leak
Yep and the leaks can depend on where/how it's parked as well.
The head gasket has never been done. Truck is not overheating and runs well, just the smallest stutter on a cold start.
It's parked on a level spot.
I was thinking of having the engine bay cleaned, but maybe I'll try the brake cleaner on some spots. I'm disabled and can't really get around to do anything more than minor.
I'm sure oil is collecting on spots other than from where it's directly leaking from/onto, so yeah a good cleaning is a fine idea. I was just trying to get some ideas of where oil can leak
thanks again,
Scott
thanks again,
Scott
thanks again,
Scott
thanks again,
Scott
A5scott (06-28-2017)
So,
I got off my *** and got on my back, and cleaned every surface I could reach under my D2. When I was under, oil was slowly raining off each suspension bar, cross member, and everything else. Oil made it all the way back to the drivers side rear wheel. Probably why that ABS sensor is bad. Probably why I was losing O2 sensors a bit faster than I should, they are caked in oil.
After scrubbing everything I could, there is nothing dripping or leaking from anywhere, aside from the valve covers of course. Two days later and not a drop on the ground anywhere under my truck.
I didn't know the valve covers outer screws need to be tightened with each oil change, or at least once a year lol. as needed I suppose.
I have all the parts to do a valve cover gasket job, and I'll have them do the coil packs while the upper plenum is out.
With the upper plenum pulled, will it be fairly obvious if the valley pan gasket is leaking enough to warrant a valley pan gasket job?
Thanks again for all the input.
So,
You'll be able to see and feel if the back of the lower intake is leaking or not.
With the engine down that far, the gasket is cheap enough to replace. Only about 8 or 10 bolts hold lower intake, and one bolt on each end holds metal clamp over end gaskets. Easy job.
If coolant is leaking from the back of the engine, around the lower intake, it's coming from the head gasket(s).
The lower intake seals in the oil from the lifter valley only.
If there is coolant there too, it's running from the back corner of the head(s).
I was talking about an oil leak in the previous post, not a coolant leak. Sorry for any confusion.
A5scott (07-31-2017)
thearmlesswonder
07-27-2015 10:16 AM
Phatrowles
01-09-2014 10:36 AM
