Oil leak
Old Jun 20, 2017 | 01:28 PM
Best4x4's Avatar
Originally Posted by Friday Night Disco
Good call out, either way I suggest some type of cleaning instead of hunting and pecking for an oil leak. In my experience, 9 out of 10 times, the oil is never coming from where I think it is.
Yep and the leaks can depend on where/how it's parked as well.
Old Jun 20, 2017 | 04:27 PM
Motorhead1's Avatar
Sooooooo true.....
Old Jun 21, 2017 | 11:24 AM
A5scott's Avatar
The head gasket has never been done. Truck is not overheating and runs well, just the smallest stutter on a cold start.
It's parked on a level spot.
I was thinking of having the engine bay cleaned, but maybe I'll try the brake cleaner on some spots. I'm disabled and can't really get around to do anything more than minor.
I'm sure oil is collecting on spots other than from where it's directly leaking from/onto, so yeah a good cleaning is a fine idea. I was just trying to get some ideas of where oil can leak
thanks again,
Scott
Old Jun 21, 2017 | 11:56 AM
Best4x4's Avatar
thanks again,
Scott
Valve covers are the most famous spot, as it can collect at the front of the engine down past the timing cover, and then get blown all over the place or down the back over the transmission and down from there. Find a 5/16 or 8mm 12point socket and tighten down the outside bolts (inside bolts require removing the intake manifold to reach), then go to town with the brake clean, it does a really good job of blasting that oil off, and go from there.
Old Jul 31, 2017 | 12:45 AM
A5scott's Avatar
Default update to oil leak
So,
I got off my *** and got on my back, and cleaned every surface I could reach under my D2. When I was under, oil was slowly raining off each suspension bar, cross member, and everything else. Oil made it all the way back to the drivers side rear wheel. Probably why that ABS sensor is bad. Probably why I was losing O2 sensors a bit faster than I should, they are caked in oil.
After scrubbing everything I could, there is nothing dripping or leaking from anywhere, aside from the valve covers of course. Two days later and not a drop on the ground anywhere under my truck.
I didn't know the valve covers outer screws need to be tightened with each oil change, or at least once a year lol. as needed I suppose.
I have all the parts to do a valve cover gasket job, and I'll have them do the coil packs while the upper plenum is out.
With the upper plenum pulled, will it be fairly obvious if the valley pan gasket is leaking enough to warrant a valley pan gasket job?
Thanks again for all the input.
Old Jul 31, 2017 | 09:07 AM
Sixpack577's Avatar
So,
With the upper intake off, and coil packs removed, you can see the top of the transmission.
You'll be able to see and feel if the back of the lower intake is leaking or not.
With the engine down that far, the gasket is cheap enough to replace. Only about 8 or 10 bolts hold lower intake, and one bolt on each end holds metal clamp over end gaskets. Easy job.
Old Jul 31, 2017 | 12:44 PM
A5scott's Avatar
Ok so may as well get that done too.
That could help stop a slow coolant leak
Old Jul 31, 2017 | 02:01 PM
Sixpack577's Avatar
If coolant is leaking from the back of the engine, around the lower intake, it's coming from the head gasket(s).
The lower intake seals in the oil from the lifter valley only.
If there is coolant there too, it's running from the back corner of the head(s).
I was talking about an oil leak in the previous post, not a coolant leak. Sorry for any confusion.
thearmlesswonder
Jul 27, 2015 10:16 AM
Phatrowles
Jan 9, 2014 10:36 AM
shonuff93
Mar 28, 2012 09:33 AM
tito5590805
Sep 27, 2010 11:32 AM
rgrizzard
Mar 6, 2008 10:16 AM
