Oil leak probable spots
Old Jun 30, 2021 | 03:16 PM
discoinfernoOSV's Avatar
Default Oil leak probable spots
So I bit the bullet and bought a '04 disco with 216k miles. Drove home fine, but had a noticable smell of oil upon getting out. Had to have a state inspection done, which it promptly failed. For the price, this was expected. Needing new rotors and calipers, fine. Has a power steering leak, but that was pinpointed. The bigger concern is the oil leak. Apparently it was leaking badly because it could not be pinpointed. This is my first car I've tried to work on so that sounds like a big deal to me. I've no idea where to start yet, anyone have suggestions on what I should check?
Thanks in advance!
Old Jun 30, 2021 | 09:45 PM
JohnZo's Avatar
My mechanic swears by the UV dye to find the source of leaks. Just don't wait too long, or it gets everywhere.
Old Jul 1, 2021 | 12:57 AM
Richard Gallant's Avatar
Get some cardboard go for a drive, at least 20 minutes put the cardboard underneath, wait a 1 to 1.5 hours go take a look. If it is leaking a lot you will get drips, but if you can smell it my bet is valve cover gasket.
Old Jul 1, 2021 | 02:22 PM
Extinct's Avatar
Valve cover leaks is a good guess. Start with the PCV mod, that will slow things down a lot - stickies at the top of the forum. Snug down the bolts on the valve covers that you can see. Clean the engine with oven cleaner (let it soak) and a water hose. Go from there.
Old Jul 2, 2021 | 10:42 PM
greisinb's Avatar
Just a heads up you will need a 1/4” drive, 12point 8mm socket to get at the valve cover bolts. It’s not a rare socket, but you might have to search around for it or order it in.
ESPN
May 3, 2012 07:42 PM
roxiemoxie
Nov 1, 2011 05:36 PM
kfox77
Apr 25, 2009 01:29 PM
newdr
Oct 27, 2008 11:28 AM
okdiscoguy
Jul 9, 2007 10:49 AM
