Oil leak at Timing Chain
I would like some updates on this as well. I have a leak that soaks the oil filter and would like to track it down. Thanks
IMHO - if you are going about testing or replacing the oil pressure switch, do a mechanical oil pressure test hot and cold, idle and 2500 rpm; to verify operation of oil pump. Spec for D2 from RAVE:
Oil pump can be cracked, make a tick, and still pump, just not enough, so you wear out engine at a much faster rate.
Pressure at idle - minimum 0.7 bar (10 lbf.in2)
Pressure at 2000 rev/min (hot) 3.4 bar (50 lbf.in2)
Relief valve opening pressure 3.4 bar (50 lbf.in2)
Low oil pressure switch opening pressure 0.24-0.41 bar (3.5-6.0 lbf.in2)Pressure at 2000 rev/min (hot) 3.4 bar (50 lbf.in2)
