Oil leak at timing chain cover...
Old Feb 28, 2011 | 10:14 PM
DiscoDos's Avatar
Default Oil leak at timing chain cover...
Just bought a 99 Discovery II. Had it checked out before I bought it and was told of a leak at the timing chain cover. I figured this would be something that I can live with for a while since it is not very bad. Is my initial thought correct or should I dive into this ASAP?
Old Feb 28, 2011 | 10:21 PM
Bundu's Avatar
Banned
It's a simple fix.
Old Feb 28, 2011 | 11:04 PM
DiscoDos's Avatar
Thanks Bundu. Will I need to remove all of the accesories off the front of the engine?
Old Mar 1, 2011 | 04:49 AM
Bundu's Avatar
Banned
No, I will point you to the service manual download rather than try to explain what needs to be done. The fan needs to come off, but you can work around most other things.
Download from here http://www.landroverresource.com/
Look for Land Rover RAVE Service Manual.
Old Mar 1, 2011 | 08:33 PM
DiscoDos's Avatar
Got it. Thanks again.
Old Mar 1, 2011 | 11:02 PM
DiscoDos's Avatar
Ok, got the Rave manual. Looked up the steps and have a question.
Do I already have the tool specified in step 3 (see below)? Is it (should it be) located on the cover itself? Please forgive all of the noob questions.
3. Locate tool LRT-12-090 on timing cover and oil
pump drive gear.
Old Aug 20, 2020 | 11:49 PM
Brandon318's Avatar
Resurrecting this thread because I'm fairly certain I have a leak coming from the timing cover gasket and have the same unanswered question this gent had a decade ago.
Old Aug 21, 2020 | 05:58 PM
Extinct's Avatar
I don't understand the question. Leaks from the front cover are typically due to the front seal, assuming you have the PCV mod. Rarely does the gasket leak.
Old Aug 21, 2020 | 08:03 PM
Red5's Avatar
If you (or the OP) are asking if you need that tool, no. “Locate” means place the tool on the cover, not find something that is part of the cover already. It’s used to center and rotate the oil pump gear so it mates with the key on the crank. Just eyeball it and work it on as you install the cover.
Old Aug 22, 2020 | 10:54 AM
Brandon318's Avatar
Perfect, that’s the answer I was looking for!
A5scott
Jul 11, 2015 07:25 PM
7smoothoperator7
Oct 19, 2014 07:09 AM
Marni
Jun 30, 2013 09:36 PM
shanechevelle
Nov 4, 2011 06:29 AM
rlrigsby
Feb 12, 2010 08:53 AM
