oil leak- what's that thingy???
Old 05-16-2016, 07:57 AM
jamestfl's Avatar
Default oil leak- what's that thingy???
so, after doing a Florida-NY round-trip recently, the Disco has sprung a pretty healthy oil leak. as best as I can trace it, it looks like the leak is coming from the bolty/thingy near the oil filter / front of the sump. no luck with looking in the Rave, maybe I just didn't see it. any leads as to what this is called? does it have it an o-ring that needs replacing? RTV?
thanks...
Old 05-16-2016, 08:40 AM
jafir's Avatar
Photos would probably help, just to make sure we are on the same page. If it were a 2003 or 2004, I'd think you're talking about the bolts where the oil cooler lines are missing, but a 2000 should have the lines hooked up there.... unless you got a new engine or oil pump at some point and a newer one was used?
Old 05-16-2016, 09:15 AM
number9's Avatar
jamestfl (05-16-2016)
Old 05-16-2016, 10:35 AM
jamieb's Avatar
You'll need to also be sure you are tracing from the source, not just the lowest point on the motor.
Old 05-16-2016, 11:17 AM
jamestfl's Avatar
a-ha! it could be the oil filter adapter o-ring. will post a photo. thanks guys.
Old 05-16-2016, 01:52 PM
DiscoBuckeye's Avatar
no chance it is the previous gasket from the oil filter from your last filter change stuck to the adapter? That would probably cause a river.
I hadn't had that happen in 25 years but recently noticed on my Jeep it stuck to the block.
Old 05-16-2016, 01:59 PM
BS50MGSXR's Avatar
that part #8 on the list, that was my jetta's problem, id loose a quart of oil in a few days. and you could see it dripping from the filter fast when the engine was running. luckily it was pretty easy to get to and replace and never had a problem sins.
Originally Posted by number9
Can you ID from this part illustration?
Discovery II Engine Oil Pump - Rovers North - Classic Land Rover Parts
Old 05-16-2016, 02:19 PM
jamestfl's Avatar
no, the leak is from higher up, like the top of the filter area.
Old 05-16-2016, 02:23 PM
jamestfl's Avatar
I loosened all of the bolts for the oil filter adapter, but it won't come off. it rotates, but seems like its stuck as in it won't come off. and with the filter adapter in there, I don't want to bust anything. suggestions?
Old 05-16-2016, 02:50 PM
Its not threaded as well?
Quick Reply: oil leak- what's that thingy???
