oil light comes on briefly in the morning
10 seconds is way too long. The fact that it varies with the temperature is indicative of a viscosity problem. Yes, you can change the filter without changing oil (you'll loose the quart or so in the oil filter), but with your symptoms, I'd be changing the oil as well. Might be something else entirely but I'd start there.
12 bucks but then ten for shipping is what I found, got a napa gold for less than ten bucks. I figure that's fine since I change every 3k. Maybe I could get a six pack of genuines online but I haven't found a deal yet...
FWIW I decided to shell out the extra $$ for a BOSCH DistancePlus filter at my last change and after pulling it apart and comparing it to an old fram and even an OE from a friends shop I was really impressed. The internals, pressure relief valve, etc are all MUCH more beefy inside.
I bet you'd be surprised if you cut open a NAPA Silver or Gold oil filter and compared it to the more expensive Bosch.
