Oil light comes on at low revs
I replaced my oil pump when I had the cover off anyway, it was not cracked and looked in good shape. I check oil pressure numbers after the gear change and got a consistent across the board increase of about 5psi. Before you do anything you really should get a oil pressure reading to verify its not a faulty oil light sensor, but its most likely a cracked pump gear and the folks who said replacing the cracked gear did not help pressure probably already had excessive bearing wear from running with the faulty pump so, the damage was already done.
It just hit 100K this week.
min624
09-07-2014 07:08 PM
marlymarl
04-21-2012 12:49 PM
