Oil light at idle
Old Jul 6, 2007 | 09:03 PM
microbc's Avatar
Default Oil light at idle
I have a 2000 Discovery II SD with 83,000 miles on it. I had the head gaskets replaced at 72,000 miles, the only maintenance it has required besides normal stuff.
[/align]The truck runs great and the only problem I have is that when I stop at idle my oil light comes on. [/align][/align]If I increase the idle (slightly stepping on gas while stopped) the light goes off. It never comes on when driving.[/align][/align]I gave it an oil change today (synthetic Mobil 1) and the light still comes on when stopped.[/align][/align]At idle it appears that I am idling at between 700 - 750 RPM's.[/align][/align]Any assistance you could give me would be appreciated![/align]
Old Jul 8, 2007 | 11:09 AM
Default RE: Oil light at idle
Tried to call you, no answer, left you a message.
mike
Old Oct 14, 2007 | 07:19 PM
foscaldo's Avatar
4wd High
I have the same issue. Have you found out what was causing this?
Thanks
Dave
Old Oct 14, 2007 | 10:56 PM
dow's Avatar
dow
dropped/clogged oil pick-up tube?
Old Oct 15, 2007 | 05:04 AM
johnnybob06's Avatar
What type of oil filter do you use?.. Have you replaced it recently?
Old Oct 15, 2007 | 06:46 AM
Landzu's Avatar
When you changed oil and started it did it knock until you got
oilpressure?
It must be a loud knock.
If this the case you havemain bearings on the crankwith to much wear, this will make the oil light come on aidle.
If you don't have the knock I would check the oil sender.
Old Oct 15, 2007 | 07:42 AM
Dave,
What year is your truck, how many miles on it and what brand of oil filter do you use?
Old Oct 19, 2007 | 08:23 AM
foscaldo's Avatar
4wd High
I use MANN oil filters. It is a 2003 Discovery with 72,000 miles on it. Any thoughts you could offer would be appreciated.
Old Oct 19, 2007 | 08:25 AM
foscaldo's Avatar
4wd High
Old Oct 19, 2007 | 09:11 AM
jwfuller's Avatar
My oil light did that on my last oil change, but quit after a few cranks. I'm still getting some rattle like a diesel at start-up. I think my remedy is to clean the pick-up tube initially, because with the problems you are having, same year truck as mine, I want to make sure everything is clear down there so if problems arise later I can look at the oil pump. It would be a good chance to replace my sump gasket.
Landzu asked about knocking, are you having any at all?
