Oil in my water pump?
If oil was coming out of water pump, then oil would also be in coolant or vice versa. As mentioned, coolant pressure tester, and closely examine. There is no oil behind the water pump gasket, but there is behind the front cover gasket. Seems like kit of both gaskets, new oil pump gears, front seal - runs about $110. But budget for a water pump and new fan clutch as well. Exam the timing chain for slop while open. And with oil pan off clean the pickup screen and renew the seal on the pickup tube.
PS: The photos don't seem to be showing anymore. I'm guessing that's why nobody else mentioned gasket sealer.
