Oil in my water pump?
Old May 26, 2013 | 01:15 PM
flanker6's Avatar
Default Oil in my water pump?
Pretty sure I know the answer, but praying for a miracle.
Is this oil coming from my water pump?
If so, my head gaskets are probably toast right?
Old May 26, 2013 | 03:55 PM
jeffh's Avatar
NO it could be the front cover gasket going.
Old May 27, 2013 | 10:18 AM
SuperSport's Avatar
Are you talking about the RED stuff? Isn't that just a gasket sealer? Is it wet or just painted on there and dry?
Old May 28, 2013 | 06:48 AM
drowssap's Avatar
borrow a cooling system pressure tester
Old May 28, 2013 | 07:24 AM
If oil was coming out of water pump, then oil would also be in coolant or vice versa. As mentioned, coolant pressure tester, and closely examine. There is no oil behind the water pump gasket, but there is behind the front cover gasket. Seems like kit of both gaskets, new oil pump gears, front seal - runs about $110. But budget for a water pump and new fan clutch as well. Exam the timing chain for slop while open. And with oil pan off clean the pickup screen and renew the seal on the pickup tube.
Attached Thumbnails Oil in my water pump?-30023360385_large.jpg   Oil in my water pump?-img564_zps5973c276.jpg   Oil in my water pump?-p1030593.jpg
Old May 28, 2013 | 07:57 AM
drowssap's Avatar
timing case cover is a pretty common leak on these, usually noticed by a water leak but not always, the timing case cover can leak oil
Old May 28, 2013 | 08:00 AM
Exactly. The front cover gasket has only a small area around the two water pump passages for coolant, the rest of the perimeter is oil gasket.
Old May 28, 2013 | 08:24 AM
flanker6's Avatar
Yes, I was talking about the red stuff. It looks brown in some areas, so I thought it was oil.
The odds are that it is gasket sealant.
Old May 28, 2013 | 08:28 AM
flanker6's Avatar
Pressure test is happening this week... Water pump and fan clutch just replaced this weekend.
Old May 28, 2013 | 09:56 AM
SuperSport's Avatar
I've used gasket sealer that looks exactly like the red in that photo, that would be what I'd think it is. Especialy if it does not just wipe off. It feels a little like hard rubber cement that's dried.
PS: The photos don't seem to be showing anymore. I'm guessing that's why nobody else mentioned gasket sealer.
