Oil oil everywhere
Oil oil everywhere
Anyone in the Denver, CO or Castle Rock, CO area good at tracking down oil leaks? My '04 Disco is pissing oil all over itself and I feel like I'm chasing my tail. I've recently replaced the water pump, thermostat, front main seal, head gaskets, rocker cover gaskets, oil pan gasket.
I'm scared the rear seal(s) are leaking. Doesn't look like the leak is coming from the front or up high. Looks like it's coming down the sides and/or the rear of the engine. It's so bad the spray on the highway is coating my rear window. I feel bad for anyone following me.
I'm up in Fort Collins right now. I'll be free this weekend if no one is closer or willing to help.
One thing that does help though is clean everything and go under when its running.
My buddies Subaru had a nasty oil leak out of no where and it was from a pinhole on the oil filter that only sprayed under high (freeway)rpms.
