I am trying to drop the oil pan on my Disco2. I have a chugging that leads me to believe that the uptake is clogged. There is one bolt (the last) that is blocked by a line. Any help is appreciated. Thanks
If it is a metal transmission line, on the driver side edge of the pan, you can gently flex it out of the way.
Make sure any of it's brackets are loose or removed first.
