Oil Pan
Old Dec 30, 2018 | 11:29 AM
N8D's Avatar
N8D
Default Oil Pan
I am trying to drop the oil pan on my Disco2. I have a chugging that leads me to believe that the uptake is clogged. There is one bolt (the last) that is blocked by a line. Any help is appreciated. Thanks
Old Dec 30, 2018 | 11:57 AM
Sixpack577's Avatar
If it is a metal transmission line, on the driver side edge of the pan, you can gently flex it out of the way.
Make sure any of it's brackets are loose or removed first.
Old Dec 30, 2018 | 12:30 PM
N8D's Avatar
N8D
Default Thanks
I was worried that I would do damage.
Old Dec 30, 2018 | 01:10 PM
Twix's Avatar
Those lines are pretty tough. You can bend them out of the way a few inches without hurting them
Old Jan 2, 2019 | 08:58 AM
DiscoBuckeye's Avatar
Just did this. Yes, the lines are very tough. I removed all three brackets that hold two lines together. Made life a lot easier to drop the pan
golgafrinch
Jan 5, 2015 10:33 PM
phidelt583
Jul 10, 2009 03:27 PM
Rover Curious
Jan 26, 2009 04:19 PM
chargersfan
Aug 25, 2007 12:22 PM
jconway
Jun 20, 2005 03:21 PM
