Oil Pan bolts
2001SE7 4.0 are the oil pan bolts a special thread or can they be bought at a local hardware store? I misplaced 3 bolts somewhere and believe they were swept out the door. Also The rubber "Plugs" on the rear of the oil pan that cover the torque convertor access are they available. Mine are all swelled and torn. Any information would be greatly appreciated.
My thoughts on those plugs: If they are intact, and in place, leave them as they are. Chances are, if you remove them, you are never going to get them back in place, because they have probably swelled several millimeters in diameter due to oil leaks. New plugs can be had from the dealer at the cost of about $12 each (from memory)
Wouldn't the bolts be SAE given the block is a 1960's GM reject?
![Stick Out Tongue](https://landroverforums.com/forum/images/smilies/peaexB2.png)
Wouldn't the bolts be SAE given the block is a 1960's GM reject?![Stick Out Tongue](https://landroverforums.com/forum/images/smilies/peaexB2.png)
0304Disco
10-15-2012 05:16 PM
