Oil Pan Bolts - Replaced stud with bolts, now have a small leak. Seal threads?
Old Dec 4, 2025 | 08:55 AM
Brandon318's Avatar
Default Oil Pan Bolts - Replaced stud with bolts, now have a small leak. Seal threads?
Basically the title - I replaced the front three studs going from the front timing cover to the oil pan with bolts (so much easier, what an upgrade) but now have a wee bit of seepage from one of them. Makes sense I suppose as the bolt holes are through holes instead of blind like the rest of the sump pan bolts. Question is - should I put some kind of sealant on the threads to prevent leaking? It's just a whisper of oil around one of the bolt heads.
Old Dec 4, 2025 | 06:08 PM
Extinct's Avatar
Yes, rtv silicone
Old Dec 5, 2025 | 05:05 AM
Brandon318's Avatar
Originally Posted by Extinct
Yes, rtv silicone
I’m assuming it just needs a really thin film so it doesn’t mess with the torque, right?
Old Dec 5, 2025 | 06:09 PM
Extinct's Avatar
Install wet, it will act as a lubricant. I use rtv on almost all bolts as loctite. Eliminates rust, loosening, and assures full clamping force.
Brandon318
Oct 31, 2025 07:48 AM
Brandon318
May 8, 2025 03:10 PM
whowa004
Feb 26, 2021 02:17 PM
0304Disco
Oct 15, 2012 05:16 PM
MrFlea1
Jan 25, 2012 10:58 AM
