Oil pan Gasket has mysterious unused holes
Old Oct 26, 2023 | 12:10 AM
DavidWrightZL1's Avatar
Default Oil pan Gasket has mysterious unused holes
Hey guys, thought I'd pull the oil pan off to take another look and see if I can find my oil leak. After my last post I was told that I needed to check the PCV and the crucifix seals. After taking the oil pan off the crucifix seals look to be in good condition but upon examining the gasket it looks like it's not doing its job. It seems to me that the top of the gasket next to the transmission is quite thin being on top of the crucifix seals were my oil leak is. I'm curious to know why there are random holes in my oil pan gasket that appeared to have no use. They're not bolt holes or guide pins. Just random holes made of some type of metal. I believe they are what may be causing my oil
leak. Thinking of using just ultra black RTV. What are your guys's thoughts?
Old Oct 26, 2023 | 10:26 AM
miron's Avatar
There are metal washers embedded in the rubber there. It's normal, they all have the holes. I'm guessing part of manufacturing process. Just make sure none of the washer are missing. I got a gasket with one washer gone and cracked the oil pan.
ShadowMerchantBC
Aug 15, 2020 11:37 AM
erick846
Dec 1, 2015 11:19 AM
Rover_Hokie
Sep 27, 2012 04:42 PM
malmberg
Sep 28, 2009 07:24 PM
kean
Feb 24, 2009 03:41 AM
