Oil Pan Hole?
Old Mar 24, 2021 | 07:04 PM
zacharyz28's Avatar
Default Oil Pan Hole?
I am working on swapping the transmission on my 2000 D2 and came across this hole in the oil pan. I took the rubber plug out on the passenger side to get to the torque converter bolts (i think that's how i get to them) and see this hole next to where the plug goes (to the right of the plug hole in the picture). Is this a hole in the pan or is it supposed to be here? I am swapping the trans because the front drive shaft locked up and broke the trans, maybe it cracked the pan too?
Thanks for the help
Zach
Old Mar 24, 2021 | 08:11 PM
woldisco's Avatar
I think this is what you're looking for: https://www.roverparts.com/engine/ga...eals/ERR7229G/
Old Mar 24, 2021 | 08:29 PM
zacharyz28's Avatar
Thanks for the reply but i have the plug. I pulled it out of the hole on the left. I am talking about the hole on the right.
Old Mar 25, 2021 | 12:33 AM
Richard Gallant's Avatar
I can check in the am, I think it is there but I am not sure
Old Mar 25, 2021 | 06:25 AM
zski128's Avatar
Yes that vertical hole is supposed to be there.
Old Mar 25, 2021 | 08:18 AM
mollusc's Avatar
You can see that there's a bolt at the bottom of it.
04disco2va
Dec 13, 2020 04:16 PM
A5scott
Nov 24, 2017 04:50 AM
abran
Feb 8, 2017 10:55 PM
Externet
Jun 11, 2014 09:47 PM
phidelt583
Jul 10, 2009 03:27 PM
