The transmission front plug...
Old Jun 11, 2014 | 09:00 PM
Externet's Avatar
Default The transmission front plug...
Hi.
Implementing the transmission fill tube on my 2000...
Got the fill tube and dipstick from a '98 donor, but unsure if the threaded coupling from the transmission pan front to the fill tube is also a donor item, of what year, or available at which vendor, or if the pan has to be retrofitted too.
Old Jun 11, 2014 | 09:47 PM
ralphobell's Avatar
Probably should have purchased the pan as well.
Not sure if you can retrofit what you have.
RTC4652 | SUMP 4 SPEED ZF AUTO RRC-DEF-DIS1 | Genuine Old Stock | Range Rover Classic - 1986 to 1991 | Britcar (UK) Ltd
PackAttack12
May 25, 2012 10:48 PM
primey
Oct 26, 2011 07:24 PM
Disco Alan
Apr 21, 2009 06:22 PM
anonimaus
May 1, 2005 05:01 AM
