Oil pan - stuck trying to remove bolt from bell housing
Old 07-25-2020 | 12:15 PM
woldisco's Avatar
Default Oil pan - stuck trying to remove bolt from bell housing
Hey all,
im trying to figure out a way to remove the topmost/driver-side bolt between the bell housing and oil pan.
There are coolant lines and the catalytic converter blocking my wrenches. I’ve tried universal joints, socket extensions, The Force, lots of cussing, ... no luck.
move watched a few YT vids that gloss over the process.
thanks for your help!
Old 07-25-2020 | 01:49 PM
mollusc's Avatar
The hard lines from the transmission to the cooler should be able to moved to one side if you unbolt the brackets that hold them.
Old 11-02-2020 | 11:30 AM
woldisco's Avatar
That worked, thanks! I just had to take that bracket off and use a little persuasion to just barely move the lines out of the way.
DiscoID (11-09-2020)
DiscoFever88
02-22-2023 04:49 PM
N8D
01-02-2019 09:58 AM
Jeff Blake
08-30-2016 09:41 PM
SailorTom
03-09-2015 08:58 PM
NiteTrain
10-19-2010 10:36 PM
Quick Reply: Oil pan - stuck trying to remove bolt from bell housing
