Oil pan - stuck trying to remove bolt from bell housing
Old Jul 25, 2020 | 11:15 AM
woldisco's Avatar
Default Oil pan - stuck trying to remove bolt from bell housing
Hey all,
im trying to figure out a way to remove the topmost/driver-side bolt between the bell housing and oil pan.
There are coolant lines and the catalytic converter blocking my wrenches. I’ve tried universal joints, socket extensions, The Force, lots of cussing, ... no luck.
move watched a few YT vids that gloss over the process.
thanks for your help!
Old Jul 25, 2020 | 12:49 PM
mollusc's Avatar
The hard lines from the transmission to the cooler should be able to moved to one side if you unbolt the brackets that hold them.
Old Nov 2, 2020 | 10:30 AM
woldisco's Avatar
That worked, thanks! I just had to take that bracket off and use a little persuasion to just barely move the lines out of the way.
DiscoFever88
Feb 22, 2023 03:49 PM
N8D
Jan 2, 2019 08:58 AM
Jeff Blake
Aug 30, 2016 08:41 PM
SailorTom
Mar 9, 2015 07:58 PM
NiteTrain
Oct 19, 2010 09:36 PM
