Oil Pressure Light After Oil Change
Old May 31, 2013 | 07:29 AM
  #21
drowssap's Avatar
I had a 5.0 sludge motor and every now and then a small piece would make it threw to the sender and block the port, tripping the light.
Old May 31, 2013 | 10:50 AM
  #22
Yoops Racing's Avatar
This all sounds too familiar .....there is a reason that you have low oil pressure. Either pump gears are shot or worse. You need to have someone look up from the pan to inspect and remove the front cover to inspect the oil pump gears...does it knock? Slipped sleeve liners are also a problem on these. The hotter to temp the worse it will get....be prepared for dire news but pray for good news ....Sorry dude...temp fix is to add thicker oil, then check the oil pressure with a tester. worse case ...need a new motor best case need new oil pump gears.
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
tito5590805
Oct 4, 2010 09:11 AM
bangkuaidiscovery04
Aug 16, 2010 11:17 AM
