Oil Pressure light, removed oil pump
Old 09-27-2022 | 03:57 PM
Jamesh007's Avatar
Default Oil Pressure light, removed oil pump
I just picked up another 03 Discovery and the low oil pressure light comes on at idle, I tried changing the oil with no change, so I pulled the oil pump, there wasn't any clogs or debris on the oil pickup and the was a small amount of sludge in the bottom of the oil pan, but I dont think enough to cause any issues and definitely below the oil pickup level, so I went ahead and pulled the oil pump expecting and hoping it would be broken or have obvious wear. One I pulled and looked at it I dont see anything that looks bad, there's an obvious front crank seal leak, but from what I see the oil pump looks fine ? I have included some pictures. Not sure where to go from here, pull one of the main bearings an inspect for wear ? anything else in the front cover that could cause the low oil pressure at idle ? any suggestions?
04in719
01-21-2018 12:15 PM
Blacktt3z
07-14-2017 06:26 PM
wheelgarage
07-14-2011 10:05 PM
DooDer
01-12-2010 10:46 PM
dinandan
04-23-2008 09:17 AM
Quick Reply: Oil Pressure light, removed oil pump
