Oil pressure sensor sandwich adapter, no oil pressure
Old Jan 20, 2018 | 03:24 PM
04in719's Avatar
Default Oil pressure sensor sandwich adapter, no oil pressure
Got a glowshift sandwich adapter and gauge awhile ago. Oil change time and just now installing it.
The sandwich adapter has two small ports,one I screwed the sensor sender into and the other I plugged. It also has two larger ports and came with connectors for that but I got plugs and blocked them.
Everything is installed ok but getting no oil pressure.
I'm thinking I got the wrong adapter? I got the part number from a thread here somewhere.
Does oil have to flow through the two bigger ports for this adapter to work properly? If so can I just run a hose to connect them for now?
Thanks all.
Old Jan 20, 2018 | 03:48 PM
04in719's Avatar
Answered my own question. Wrong adapter if you just want a sensor installed.
The one I got was for an oil cooler and sensor install.
The two larger ports must flow oil.
Now, to exchange for the correct sandwich adapter or install an oil cooler ;-)
Old Jan 20, 2018 | 04:03 PM
OverRover's Avatar
What part number did you buy? The plate can be a GS-AF2 with 3 ports and you just block the ports you aren't using. At least that's what I did last time I installed one of these.
> https://www.glowshiftdirect.com/oil-...unf-16-thread/
Old Jan 21, 2018 | 07:39 AM
Lisa Bunch's Avatar
I have a 2000 with the engine oil cooler so I bought the tee fitting to go between the factory sender/timing cover. Should get it Tue/Wed, bought it on ebay $13. I thought 04's you could just remove a plug on the timing cover and use that port.
Old Jan 21, 2018 | 12:15 PM
04in719's Avatar
If there's a port on the timing cover for a sender I'd love to use that.
I'll look and search the forum; if anyone has a picture or two of an 04 with the 4.6 using an OE port on the front cover that would be helpful too.
Thanks again all; as always appreciate the feedback.
caymandrew
Feb 4, 2020 08:03 AM
grammin
Sep 1, 2017 08:12 AM
ericcooke
Mar 2, 2017 11:20 AM
jpluncford21
Jan 31, 2017 08:19 AM
aemnky606
May 23, 2010 06:06 PM
