oil pressure plug
Old Feb 14, 2023 | 10:24 AM
mackendw's Avatar
Default oil pressure plug
picked up a replacement plug for a 4.6L front cover for the oil cooler line (not used on mine). I am assuming that the tap in the plug goes thru from the large end straight thru to the end inside (same diameter). Is there a mininum size that this hole has to be for an accurate reading? threaded end tap would go just enough into the top portion to secure the adapter for the oil pressure kit. correct?
Old Feb 14, 2023 | 06:36 PM
Extinct's Avatar
Ports in gauges usually are about 1/8 or less, so you can just drill a small hole all the way through. Drill the tap hole sliightly deeper than your fitting length.
Old Mar 20, 2023 | 05:27 AM
mackendw's Avatar
just getting to this task today. have the drilled/tapped oil cooler plug replacement ready to go in to take the pressure tests.
question on the original plug when I put it back in. how tight is good? ie: is there a torque spec for this...don't want to crack the housing.
Old Mar 20, 2023 | 11:24 AM
redwhitekat's Avatar
becarefull where you plug your sensor to, you will get false reading, if you plug inti oil cooler, might be better to get a oil filter adapter for proper reading of pressure
Old Mar 20, 2023 | 01:43 PM
mackendw's Avatar
OK, I used the plug to the left of the oil filter housing just above it. It's where the oil cooler line would plug in. easily accessible. The oil pressure is as follows:
cold at idle of around 600rpm: 54psi
cold at rpm of 2500rpm: 56psi
operating temp (~175F) at idle: 30psi
operating temp at 2500rpm: 45psi
So, given these numbers, I should be OK on the oil pump.
Old Mar 20, 2023 | 05:28 PM
Extinct's Avatar
Yeah, those numbers are pretty good
Old Mar 20, 2023 | 05:38 PM
mackendw's Avatar
onto the underbody rust now....oh joy!
mackendw
Feb 9, 2023 09:29 AM
cvhyatt
Jan 9, 2022 10:35 PM
neuropathy
May 15, 2021 01:27 AM
JettsRover
Apr 7, 2018 12:04 PM
redrover75
Jun 30, 2015 05:50 AM
