Oil pump in my 04 Disco II failed last night.
Old Jul 17, 2011 | 07:48 PM
  #71
RoverMasterTech's Avatar
Originally Posted by adeso
Its back together, running smooth. Power steering pump is making a little noise but I think it just has some air in the system, every thing else seems good. going to drive it 25 miles then change the oil.
Nice dude, glad everything is ok. If you took the PS pump off you need to bleed the box. With the car running crack the bleeder on the steering box with a long extention and deep 11mm socket. (I think its 11mm)
Old Dec 19, 2011 | 11:03 PM
  #72
2001SE7's Avatar
Default Warning; Do Not Buy A Used Motor From Engine and Transmission World
If you are looking for a good used motor do not buy it from Engine and Transmission World; They are as crooked and a millennium in long. If you don't believe me just google them and read the reviews/complaints. They have a F- rating with the BBB. Crooked Bastards.
Old Dec 22, 2011 | 09:47 PM
  #73
2001SE7's Avatar
Its strange how he described it to me, driving down the road and loss of power, running rough but still running then sprayed oil all over the place, the way he described it sounded like he dropped a ring. I haven’t seen it yet but I'm going to get my hands on it tues and should have a much better idea what’s going on. I have no idea what is going with the timing plate cover. Haven’t played with the discos at all so I'm sure I'll be back on here after I start digging around. Thanks in advance for the help guys.
Hi adeso. I was reading this thread and all of the sudden you joined the discussion fully involved with this guys motor. I am just curious how that happen as I didn't read anything leading up to you taking over the project. Did you PM him when he asked if there was anyone close to his area that works on Rovers? Sorry to be off the subject but when I miss something I got confused and curious. Thanks.
Old Dec 23, 2011 | 11:45 AM
  #74
2001SE7's Avatar
Originally Posted by DiscoRover007
If he just replaces the timing cover, won't his pump eventually fail again? **** I'm confused.
That's a very good question, I wonder why RoverMasterTech didn't answer that. That question probably comes up a lot on 2003's.
And from reading I could never quite figure out; was this motor pulled or was it repaired with it still in the truck? Thanks.
Old Dec 23, 2011 | 12:48 PM
  #75
adeso's Avatar
I knew the guy and decided to help him. It was done with the engine in the truck. Due to poor maintenance the oil was sludge which caused the oil pump to fail. I dropped the pan, flushed everything with ATF put a new front cover/oil pump on it and it was good to go
Alex J
Dec 17, 2010 12:31 AM
skatelove303
May 11, 2010 10:37 AM
booyah7
Aug 10, 2009 11:50 AM
southfloridadiscoII
Jun 28, 2009 11:03 PM
luxury1
13
Feb 26, 2009 09:55 AM
