Oil Question - Castrol Edge 5w-50
Where does one find ZDDP charts? I used either Pennzoil or Napa (Vavoline) 5w30 dino SJ spec (as requested in the owners manual) for my winter driving as Utah ambient is well below was Rotella 15W40 is specified for.
Even though it's only for 3 months and not many miles, I'd still like to pick the best lightweight oil for winter use.
Also, has anyone had any premature cat-converter failures or clogging by using ZDDP (the reason for oil manufacturers going away from it)..
Abran, Alex and others may be the best source but the three rover engines I have opened (a couple repeatdedly) looked new with rotella after more than a hundred thousand miles. Ditto for the Mercedes. The one rover engine that I opened with regular dealer changes looked like a dirty diaper inside.
ZDDP , (zinc/phos) is not a cleaning agent,!!
It's added to oil as extreme pressure wear protection , and it came about 1950's with low contents in oils , and eventually got to about (1000ppm to 1300ppm) early 70's,, (for most gasoline engine oils).
(ppm=part per million),,
Diesel oils always had a little more ZDDP compared to gasoline engine oils,,
But ZDDP is not responsible for cleaning inside of an engine by itself,,!!
And now there is a debate that there are newer extreme pressure agents , than ZDDP,
That being said , I personally wouldn't take a chance using newer oils (with lower than 1000ppm ZDDP) on flat tappet pushrods engines ,
(but I do use newer better oils for newer design overhead cam engines)
So if an oil does a good job cleaning inside an engine,, it doesn't necessarily mean that it also did a good job of lubricating !!!
Good lubrication of different parts , is the. Job of good base oil formula NOT ZDDP content by itself,,!!
So for our Rover engines, you want a good base oil that has min of 1000ppm ZDDP, and change it frequently,,,
Keep in mind all synthetic oils are inharantly cleaning engine surfaces,
But,, it doesn't mean all synthetics are equal in lubrication, ( there is a big difference in lubrication capability of diff. synt. oils from diff brands, also big difference in diff. Products/weights. from same brand,!!!)
Also ,, there are some conventional oils that are better than a lot of more expensive synt oils, as far as wear lubrication is concerned,!!
((There are very few exceptions,)) but in general, most diesel oils are not as good as, best gasoline engine oils...
just because an oil provides adecuite protection in an engine, doesnt mean it's the best oil, But that it is just "good enough" to do that job, and when something bad happens (over heating/lack of oil high pressure/etc,,, most people don't realize maybe if they had best oil for that application, it might have saved the day,,
By the way a very, very expensive oil , doesn't always mean the best ,!!
There are so many lower priced products , that will outperform , highest priced , hyped up, products,..
LandRoverNews
Defender
Dec 12, 2011 12:27 AM
lipadj46
Jun 15, 2009 10:29 AM
